I think it is broken beyond repair
frenchfries
Post by frenchfries » Mon Jun 19, 2017 3:17 pm
No wonder the door won't stay open half-way or fully opened. Not sure how I can fix this.......
Re: I think it is broken beyond repair
Post by Alan 480 » Mon Jun 19, 2017 6:07 pm
phot is a bit fuzzy :wink:
is that the hinge or just the 'steady bar' . .. . ?
you could just plate in behind / sandwich bit of steel? it as not an MoT part . .. . .
frenchfries
Post by frenchfries » Mon Jun 19, 2017 8:59 pm
Alan 480 wrote:phot is a bit fuzzy :wink:
It Is the plate that holds the inside hinge on the door :(
Or maybe have it welded inside?
Post by jifflemon » Wed Jun 21, 2017 10:25 am
Door off would be the starting point, just for access.
Plate over it. What colour is the car? Replacement door from the eBay?
frenchfries
Post by frenchfries » Wed Jun 21, 2017 10:32 am
jifflemon wrote:Door off would be the starting point, just for access.
Skip is Vase Green (vase in French means green mud by the way). Finding one and having it shipped would be something let alone respraying if necessary. I think I will shop around for a welder but not during the Summer months, I am wasting enough time as it is :)
