Hi all
I have received the set of front seatbelt pads (that go over the shoulder), I thought there would be a velcro to wrap them around the belt but they need to be slid in, do you know how?
Best
Moi
Front seatbelt shoulder pad
Re: Front seatbelt shoulder pad
You will need a 5/8" (yes that is not a metric size though 16 mm will come close) wrench, with which you can undo the bolt that holds the seat belt holder (a fairly large and bent metal bit next to the seat) to the chassis. Now you can remove the seat belt end and slide the shoulder pad around it.
Hi Brinkiebrinkie wrote:You will need a 5/8" (yes that is not a metric size though 16 mm will come close) wrench, with which you can undo the bolt that holds the seat belt holder (a fairly large and bent metal bit next to the seat) to the chassis. Now you can remove the seat belt end and slide the shoulder pad around it.
I had just done that to replace the seat-belt extending arm, I see what you mean now, thanks for that
