Centre Vent Removal
Dancing Demon
Centre Vent Removal
Post by Dancing Demon » Wed Apr 19, 2017 10:24 pm
I am sure there are posts about this - but I cannot find any!
How do I remove the actual 'vent' from the centre console surround. This is the vent unit which swivels from side to side, and then there is the centre lever which allows the 'fins' to point either up or down.
Many thanks
Chris
Re: Centre Vent Removal
Post by dcwalker » Thu Apr 20, 2017 7:45 am
It prises out, just like the other vents do.
You just have to be very very careful since, as I am sure you know, the plastic of the dash surround that holds it in place is very brittle.
Why do you need to remove it?
Post by dragonflyjewels » Thu Apr 20, 2017 7:45 pm
I've used Mannol silicon spray on the plastics and it makes them a bit less brittle. Does a great job on rubber seals and hoses as well.
Post by jifflemon » Thu Apr 20, 2017 7:57 pm
Not a fan of silicones.... my paint man would batter me if I dared use them.
For rubber seals, this is pretty much unbeatable
Post by dragonflyjewels » Fri Apr 21, 2017 10:04 am
O gawd, just been reading up on my sins, I shall have to eat humble pie when I arrive at the bodyshop this afternoon. He'll be pleased to know that I've only done 2 of our cars, and 90% of the 2 spray cans went inside the cars or on bits that had been removed and taken into the nice warm conservatory. Only 10% to worry about.....
Dancing Demon
Post by Dancing Demon » Sun Apr 23, 2017 7:24 pm
Thanks for replies.
The reason fro removing the vent is it is broken at the back in as much as the fins all go in different directions.
Kind regards
Chris
