Plastic Clips for Door Card
Post by Martin Mc » Thu Aug 18, 2016 4:28 pm
Hello folks,
Wondering if anyone might have (or know where I can get) the plastic clips for attaching the door card?
Also Jim (GJ) if you are still with us, do you have any more replacement heater knobs (the ones that discolour)?
Cheers!
Previous 480 pedigree: 1992 ES (1.7 White) 1993 ES (2.0 Red) 1994 S (1.7 White) 1994 ES 2.0 (metallic red) 1995 S (1.7 Black) #467 / 480 Celebration (flame red metallic) 1993 ES (2.0 Paris Blue)
Every decent bloke deserves an extra-marital car (so my wife tells me)(apparently it keeps me out of mischief.... really..)
glasgowjim
Re: Plastic Clips for Door Card
Post by glasgowjim » Thu Aug 18, 2016 4:59 pm
yes still with you :lol:
you are looking for cheese wedges and they are listed in my thread how many do you need as they are in first class condition :hopping:
have been driving about uk for the last 2 days and just recovering today :D
need to rename england => roadworks land
replace the union jack with a traffic cone on white background :lol:
Post by Martin Mc » Thu Aug 18, 2016 7:25 pm
Hello Jim,
Sorry to hear you've had problems on the roads - it's just another thing that the government have been telling porkies about, whilst paying their mates in the banks and FTSE 100 companies for 'maintaining' the UK's infrastructure.
I could do with a full set of wedges for each side door card, as the ones in there at the moment are few and far between and in poor condition. Not sure how many that would be, but I'd guess approximately 8 per side?
Happy to pay the going rate plus postage.
All the best!
glasgowjim
Post by glasgowjim » Thu Aug 18, 2016 9:18 pm
cheese wedges = heater slider knobs :rofl:
Post by Martin Mc » Fri Aug 19, 2016 6:16 am
glasgowjim wrote:cheese wedges = heater slider knobs :rofl:
Ah, Oops!! I guess I don't need 8 per side then :rofl: :hopping:
Just the one set if possible pls. Should I PM the address etc?
Post by Martin Mc » Fri Aug 19, 2016 10:44 am
Still need some of the plastic clips for attaching the door card... where is the best place to find the right kit?
M
malkontent
Post by malkontent » Fri Aug 19, 2016 11:15 am
Hi
Have 4 pcs. new , 3121595 clips , total is 8GBP + post .
480 Expert
Post by brinkie » Fri Aug 19, 2016 7:44 pm
Martin, I am going to break a 480 S in September (MOT fail because of terminal rust), I will try and salvage the door clips.
Post by Martin Mc » Thu Sep 08, 2016 6:24 pm
brinkie wrote:Martin, I am going to break a 480 S in September (MOT fail because of terminal rust), I will try and salvage the door clips.
Hello Robert,
Much obliged - let me know if any clips survive :)
480 Expert
Post by brinkie » Thu Sep 08, 2016 8:54 pm
Well I thought I'd save a bunch of those clips for you, only to find out the ones on my car are completely missing :shock:
Now I know, after two years of ownership, why the door cards are squeaking so loudly: there's really nothing to hold the underside to the door...
Anyway, I should find more sources of those clips. I'll keep you posted (no pun intended :lol: )
glasgowjim
Post by glasgowjim » Thu Sep 08, 2016 8:58 pm
martin you have a pm :D
fireblade
Post by fireblade » Tue Oct 22, 2019 5:05 pm
I need some plastic door clips.
Do you know someone that sells it?
Post by Alan 480 » Tue Oct 22, 2019 7:12 pm
are you sure they are missing?, assuming that those being requested are those along bottom edge of the door?? I just discovered that mine were NOT missing as the later doors are held on with 'hidden' clips that might have 'disbonded' from the pressed chip-board inner . .. . .
the door card/vinyl still looks as if it should have the bottom plastic clips !!!!
i glued the pastic back onto the chip-board with a 'evo-stick' type glue. in reality the same stuff i'd used for the head lining. time will tell how well it works. the other one has a self tapper neatly inserted at trailing edge at about 'half past four' position :wink:
Post by dcwalker » Tue Oct 22, 2019 7:21 pm
...the other one has a self tapper neatly inserted at trailing edge at about 'half past four' position :wink:
My simple solution to avoid wondering if glue would hold - if I'd got round to removing the driver's door-card too you'd probably have a matching pair now! :lol:
Jaster
Post by Jaster » Tue Oct 22, 2019 8:43 pm
My '94 car has both the clips along the bottom and the push-fit clips on the back of the door card. The latter are a nightmare to get back on in my case and I've destroyed at least one of them, but the door card stays on fine without them if you have the bottom clips as well, at least that's been my experience. The older car only has the bottom clips.
Is this the part you're looking for? If so then they can be 3D printed.
fireblade
Post by fireblade » Wed Oct 23, 2019 12:24 am
I need 2 that are broken.
The part number is 3121595.
Jaster
Post by Jaster » Wed Oct 23, 2019 6:47 am
Post by Alan 480 » Wed Oct 23, 2019 7:34 pm
David, I was actually referring to the red car :hopping: not really noticed the passenger side so can only assume that the self tapper is working 'just fine' :-)
so 1993 only bottom clips,
1994 both
1995 only 'press studs'
or is that too simplistic?
Jaster
Post by Jaster » Wed Oct 23, 2019 9:22 pm
I can't confirm with absolute certainty, but I'd wager that if anyone here has a '95 car with no clips along the bottom then it had them when it was new but they've fallen off in the meantime, probably when the door card was removed in the past.
Post by dcwalker » Thu Oct 24, 2019 7:37 am
1994 both
Ha - yes, thinking about it you said "half past four" whereas the one I added is at the rear corner IIRC, more half past seven...I am obviously not the first person to have that bright idea! :lol:
If it helps, my 1994 GT has press studs and clips along the bottom BUT only the two nearest the front - there is no sign on either door of the rear holes ever having had them in place, and as far as I know I am the first person to have removed the door cards. The 1995 Celeb has none along the bottom now, but - as Will surmises - the broken off remains are there still (but again, not in the rear holes).
