Air conditioning compressor and other headaches
Posted: Tue Jun 07, 2016 10:51 am
I could have pushed my car to a cliff this week.
Through the winter I have spent about 700 euros renewing all my air conditioning system. New compressor in september. Had fitted a new dryer filter from a Ford Focus with a complete renewal of all tubes from the radiator and upwards.
The system was working good until a couple of weeks aog whe my wife had to call for asistance on the road as the AC compressor started throwing up white smoke. The compressor was still in warranty so It is now being replaced, but the aircon guys say the've never seen a compressor piston rod melt like this. They argue it must be due to continuous system overpressure. I argue the the system has a overpressure switch that disconects the compressor when it reaches a certain pressure and that this is nothing but a faulty compressor. They will replace it no matter what the reason has been.
Later this week I was talking with this AC specialist who said to me that all conversions from R12 gas systems to R134a are doomed to fail due to the different tubes caliper of R12 vs R134a systems. But again I'm not sure that my car was a R12 system. It's a midst june 1991 turbo (chasis 566555). According to the partsbook my fitted compressor part is 3450073 (3416338) wich is a R12 compressor. But when I search my compressor in Oscaro, Autodata and other databases it allways points to a Sanden SV7V16 wich is a R134a gas compressor. They are both two level pulley compressors, one 120 mm level with 6 grooves and a bigger 130 mm pulley with 3 grooves. I don't know if my car was fitted with a R12 or a R134 compressor when i bought it two years ago as the compressor had no sitcker on it....
https://www.recambioverde.es/compresor- ... 94101.html
https://www.recambioverde.es/compresor- ... 90520.html
Wich reference of compressor do you think my car had? Would you keep putting money in this bottomless hole?
