boot bolts
JimAitken
boot bolts
Post by JimAitken » Mon Mar 14, 2016 5:27 pm
I'm tackling the surface rust in the boot area and in the aquarium where the toolkit floats, are two bolts. What do they hold up under the car? And if I remove them to kill the rust round that area, what is likely to drop off? How about one at a time maybe? They look like they are linked to an anti-roll bar or something. Is there a nut at the other end (leaving myself open to that question!).
cheers
Jim
current: 480GT, V70 D5
previous: 480Turbo, 440, 850, V70 Classic. Renaults 4/5/6/20, Mini Cooper S (1968), Alfasud ti
Rob Houston
Re: boot bolts
Post by Rob Houston » Mon Mar 14, 2016 11:24 pm
Snap! I'm doing roughly the same thing in the same area! The two bolts attach to the chassis cross-frame member. Removing them will not affect anything, you still have four more underneath before anything falls off :D
Regards, Rob Houston
The car in front is possibly going to be a C30 - and it's staying there!
Previous: 1994 480 ES, 1994 480 GT, 1994 Celebration, 1995 Celebration #286, Celebration 293. All passed on to the BIg Crusher!https://www.volvo-480-europe.org/forum/ucp.php?i=ucp_profile&mode=signature#
JimAitken
Re: boot bolts
Post by JimAitken » Tue Mar 15, 2016 6:15 am
Rob Houston wrote:Snap! I'm doing roughly the same thing in the same area! The two bolts attach to the chassis cross-frame member. Removing them will not affect anything, you still have four more underneath before anything falls off :D
thanks for that Rob
Re: boot bolts
Post by Alan 480 » Tue Mar 15, 2016 12:58 pm
BUT an MoT man might ask about corrosion around that area :-) . (I had a 'fail' once when they reckoned that the four M6 bolts were 'structural' ) I've removed the bolts (Made a new cross member) and blanked the holes
WRDendy
Re: boot bolts
Post by WRDendy » Tue Mar 15, 2016 1:38 pm
JimAitken wrote:I'm tackling the surface rust in the boot area and in the aquarium where the toolkit floats, are two bolts.
:lol: That gave me a good laugh!
Formerly known as 'Jaster'
Current: '94 GT & '88 ES
Former: '89 ES
JimAitken
Re: boot bolts
Post by JimAitken » Tue Mar 15, 2016 2:03 pm
good point, especially as MOT is coming up. Probably a good idea to replace the bolts with nice new shiny ones. I'll check the other ones under the car.
