Vandalised drivers side door lock.
- Tee
Hey all,
My 480 was attacked the other night by some hooigan with a sharpish impliment. It looks like they've jabbed something and given it a good wrench around. Anyone got ideas on the best way to get it fixed?
https://db.tt/9tdfC0Fn
https://db.tt/1snxAvm1
I've been able to lock and unlock the door a few times, but I think now I am not able to to lock it any longer. I tried for 10 minutes tonight, and it wouldn't budge.
--- Tee ---
Re: Vandalised drivers side door lock.
This has been an attempt to break in and maybe even steal your car. Apparently it took the thieves to long, or they got interrupted. They might come back!
you get a replacement lock barrel and if needed levers/latches these small brass latches and are numbered 1 to 4 you then simply remove the plastic backing triangle from the inside of the door remove the retaining clip insert the key into the lock barrel and pull out the lock barrel. Be careful the latches have a little spring underneath them so dont lose any.
I know a man who has spares of these things
But first make sure you can remove the barrel and that the actual lock itself is not damaged.
Oh it is a simple job not difficult.
- Tee
I think I'll need a replacement front part of the lock won't I? How will I get one of those?
--- Tee ---
you only need the lock barrel it includes the "silver" metal part that is mangled.
I can supply a lock barrel you have a pm
Jim, exact same thing happened to me about 20 mins ago, heard them outside opened the front door and they legged it, door locks and unlocks fine just the front of the lock got messed up as per pic in Tee's first post... Do you have some bits that will let me repair the damage? I can only assume they wanted the car as panel is off radio and in the house.... Would have prefered they went for my XJ8 parked right in front of it !!
C
C
'88 Volvo 480 ES
'97 Volvo 940 Turbo
'97 Volvo 940 Turbo
gl its the same with me everytime I park the rolls outside no-one touches it .
Yes I have a replacement barrel. You have a pm
Oh by the way the door locks are not sided. but the rear hatch lock barrel is longer
