Another question...
My (german) 1992 480 is equipped with headlamplevelling. Too bad it doesn´t function at the moment and i can´t find anything on this system in my Haynes manual. There is a switch in the centre console which can be turned, but nothing happens after that. I couldn´t remove the switch so far (any tips?) Near the headlamps i found some white tubes, could they have something to do with the headlamplevelling?
Thanks for thinking (and replying)
Joost.
Headlamp levelling
There must be blue fluid in both white pipes (connected to the headlamp's body). If not: this is another common fault of 480 cars due to cracks let fluid escaping. You can also check pipes at the switch end simply pulling the swich, prising off the numbered plastic, and unscrewing the two bolts.
(DO NOT unscrew the 1 screw under the switch, you will never be able to refit!)
If you have fluids inside, check headlamp end black heads (with small rods) moving the lamps. If they are corroded they do not move. Remove rust.
If the system is leaking (I have two of these with 1-1 pipes leaking) you must buy a new one. Dealers sell it only complete and extemely expensive.
Peter
Peter
