Bonnet light
- V480t
Bonnet light
Hi to all,
Only recently i heard talking about a bonnet light. Can anyone tell me where is it?Because i´ve never seen it in my car.
Thanks!
480:Even parked runs like hell!!!
Thanks!
- Ben Harris
My '89 doesn't have one, but then it didn't have a digital clock either. Another member (whichone) mentioned that her '89 did have a digital clock, so maybe this is the year which several things changed? I'm sure I've seen other '89s at the scrapyard which have had bonnet lights...gerrsvolvo wrote:Not all 480´s have bonnetlights.
The earlier ones had it but I do not know exactly up to what model
year.
I think 1986 to 1988 or ´89 have it.
Later was the opening in the bonnet not there.
Good CEM
gerrsvolvo
Ben.
- dragon
- Volvo 480 Club Europe CREW
Not only did the bonnetlight seem to adorn very few cars, in later models, Volvo removed even the option to fit one - my 1995 480 doesn't have the right hole/recess where the light used to fit on the earlier models - where my 89 ESs had a definate recess at the top where you could fit the light, the 1995 model is just "staright across" if you see what I mean... bah!
Gaz Wilson
Gaz Wilson
- strangegame
- dragon
Seems really hard to find a decent pic of the underside of a 480 bonnet, so I can't show you exactly, but you'll know what area to look at on the following - basically there's a recess somewhere near the bonnet spring (behind it?) - obviously this is from memory as my car isn't here to double check - if someone wants to take a better photo of theit bonnet, we can show you exactly!
Gaz Wilson
Gaz Wilson
- volvofox
there are even two kinds of bonnet lights. My '88 turbo had a straight clear "dome" by hella, made this way it didn't blind to much, the early ones had even a switch..
switching the bonnet off can be handy, as working on electrics, or loading the battery, but the problem is, there is still batterydrain with the light off, because there is a circuit via the cem towards alarm/door open light.
Be aware the first 480's were the most complete ones... I think of bonnet lamp., grips with lamps above rear seats, digital green timer with stopwatch, weight dependant brake power changer, etc
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
