Tow bar poll
Tow bar poll
My 480 is equipped with a tow bar, which I have never used. Being the second owner of this car I can't be blamed for this accessory and because it is detachable it does not look too bad (but it is another thing to say it is stylish).
What is your opinion on this? And do you have or want such a piece of iron?
Ernie
1992 480 turbo automatic paris blue 200.000 km
- Ben Harris
I had one fitted to my 480 when I first got it, but I've taken it off as I never intended to use it, and don't think it suited the styling of the car. After my 480 was lowered, it certainly didn't look right, and probably wouldn't have been able to tow anything anyway! At least yours is detachable though - mine was an aftermarket one.
There was someone advertising a second hand, non-original Volvo one, a while ago. They wanted about £100 for it, which I thought was a bit (very) steep!
Ben.
Ben.
- dragon
- Volvo 480 Club Europe CREW
had one fitted to my second 480 whenI got it, but I had to have it removed becase all of a sudden it started failling the MOT because the ball slightly obscured the reg plate
Passed for many years before.
I don't think the 480 is made for towing anyway...
Gaz Wilson
Gaz Wilson
- coyote1980
Here in Holland yuo must have a tow-bar! It's almost tradition
I even know of jokes made by radio-stations where they call a kwik-fit dealer and pretend to own a Ferrari and say they want a tow-bar under it , always great to hear a response to that.
But back on topic: being dutch both my 1987 had and 1996 ES has a tow-bar! (OK, fitted by previous owner, but tow-bar is towbar )
I've got one on mine, but I don't think I'll use it. I would only need a towbar for towing the horses, but as I havn't got a trailer, it won't be used...and we've got a 760 for towing !
480's aren't made for towing.
But I might keep mine just incase someone wants to drive up the back of me...
N.B. French drivers are no good...well in the Charente Maritime anyway...
480 Turbo > 1989 Graphite Grey
MR2 MK1 > 1989...
[img]http://membres.lycos.fr/cosworth/la_team-bordelaise/Sophie.gif[/img]
MR2 MK1 > 1989...
- chris1roll
Had one on the first 480 I ever owned, fitted by its previous owner. Was useful for towing small trailer of rubbish to local tips, but that's about it. Also handy for rear end shunts, was in my dads old Rover with towbar, going to college when a Metro decided to impale itself. I thought it was very funny as I suffered no damage apart from a twisted electrical socket, can't say same for the other car. That was in the days before metros had turned into rust buckets. 1987 - yes I know I'm getting on now!
- volvofox
hey yes, a trailor hitch please ! I am also looking for a front and rear electro hydraulic 3 point hitch, catagory II, a 3 valve double electro-hydraulic valves (SCV's) and a 3 gear front and rear pto please, also common rail tech, four valves per cylinder, electronic steered fuel pump "constant power" dependant of electronic controlled parameters "vario" hybrid mechanic/hydraulic constant variable gear box, GPS etc. etc.
Only kidding, but I wish sometimes our car was as technological advanced as a modern tractor.
I don't think you must be so prejudged about a trailor hitch !
I think if you think its ugly this is your problem between your ears, It has numerous safety advantages, and it comes handy.
You just have to hitch on a trailer that suits a 480, like a small caravan, a one horse trailor or similar small and light one axle trailors..
I think the clutch is (must be!) tough enough to whitstand. A small disadvantage is however there is not enough torque in petrol engines like ours in the low revs.(unlike diesel) the engine will stall, you must drive a way with a "slipping clutch" keeping it half engaged. this is bad., so try to prevent this.
so nothing is impossible...
again, i find it to be a pitty i haven't got one.
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
