This is in engine compartment and seems to shield the brake pipes from Master cylinder from the exhaust pipes.There are two screws holding it to the bulkhead and the other end I think fastens to the inner wheel arch.Mine has snapped off at the wheel arch end so have it wedged with a thick piece of rubber at the moment.Have not a clue how it can have happened-except I did have to have a new Master cylinder a few weeks ago fitted at the garage-wonder if they know anything about it!
It had dropped down a bit and was rattling on the timing cover-I thought I had something drastically wrong as it took me a while to spot the problem.It looks a fiddly job to replace.If anyone has a good one I would appreciate a mail.
As an aside,I have just had the rear wheel arches replaced as they were getting tatty and the Ford arches suggested elsewhere in this forum have made an excellent job.Thanks to whoever it was who posted the information.
Shielding plate wanted
Re: Shielding plate wanted
stick it back on with SIROFLEX 300c heat resistant slicon sealant , £4.13 a tube (for a mastic gun) from TOOL STATION , about 70 branches in the uk or buy online
Cheers Felyx
Cheers Felyx
