Zerbot
Post
by Zerbot » Mon May 25, 2009 5:17 pm
what size is the torx that holds the seat to the floor ?
H.
Snabbe
Post
by Snabbe » Mon May 25, 2009 7:22 pm
T50
ted clutch
Post
by ted clutch » Tue May 26, 2009 12:23 pm
youl need to be he man to get them off.
pol
Post
by pol » Tue May 26, 2009 2:00 pm
I must be He-Man.
(Or I used a blow torch on the threads underneath where possible.)
pol
DaKyy
Post
by DaKyy » Tue May 26, 2009 2:07 pm
I opened them with my bare fingers.
Well they are quite tight but it is doable with a ratchet wrech.
glasgowjim
Post
by glasgowjim » Tue May 26, 2009 4:16 pm
it varies some are tight some impossible and others quite slack just like women!
Zerbot
Post
by Zerbot » Wed May 27, 2009 11:27 am
hehe they sure are tight if they are ,
one more question about seats and so , how do you remove the back seats , didnt see any bolts or anything ,
do i have to remove the armrest inbetween first or is there some other way i should engage ?
H.
Zerbot
Post
by Zerbot » Wed May 27, 2009 11:30 am
glasgowjim
Post
by glasgowjim » Wed May 27, 2009 4:20 pm
Need I say more
B18FT - LOVER
Post
by B18FT - LOVER » Wed May 27, 2009 6:55 pm
glasgowjim wrote:it varies some are tight some impossible and others quite slack just like women!
Trouble is there's plenty of tight bolt's but not enough tight women .... Pmsl...
Snabbe
Post
by Snabbe » Wed May 27, 2009 8:18 pm
The rear ones are harder because the bolts ends up under the car, and there they become very rusty. You can see them sticking out through the floor.
pol
Post
by pol » Sat Jun 06, 2009 9:53 am
Me and He-Man were just working on some seat bolts. Snapped one TX50 bit, but got it replaced under lifteime waranty (thanks halfrauds!).
Seat rails on the passenger seat were stuck so had to take the seat to bits.
The last bolt's head has just stripped on me
It was going so well!
Angle grinder time.
pol
ted clutch
Post
by ted clutch » Sat Jun 06, 2009 7:08 pm
i tried to get the rails up to give me more leg room , i had to admit defeat with my limited outdoor workshop.
DaKyy
Post
by DaKyy » Sat Jun 06, 2009 7:43 pm
To ease it up I suggest you remobe the backrest. Tilt it all the way back down so the pins holding the backrest come up. Pull the pins off and undo the nuts holding it to the seat. Quite easy to do and gives you a bit more room to undo the bolts.
