Are my Shocks knackered?
- Big Brother
- Moderator
I know it is only the casing but now won’t dirt and mud cease it up or something? In the pics is my rear passenger side shock with the casing how I found it and then when I removed the sharp rusted bits of metal from around it. The driver side is badly cracked and rusted too
2001 V70
- dragon
- Volvo 480 Club Europe CREW
Ouch!!!!!
Yeah, I'd say now was the time to consider changing those! To be honest, they are almost certainly the original shocks as it left the factory!
Gaz Wilson
Gaz Wilson
- Big Brother
- Moderator
- dragon
£17.95 + VAT each from GSF seems to cover it mate.
Gaz Wilson
Gaz Wilson
- dragon
You wouldn't want to run with them long term though, surely?
Mind you, no use asking for your opinion, John... you don't have a good
track record when it comes running with good condition shocks, do you?!??!
Gaz Wilson
Gaz Wilson
- Big Brother
- Moderator
- dragon
Yeah, the rears are a doddle Fronts would require a spring compressor though
Gaz Wilson
Gaz Wilson
Those photos could be off my car! Had the tracking done today, and whilst it was on the ramp had a good nose around underneath. Usual stuff, leaking sump plug blah-de-blah, but the rear shocks look identical to those above.
Bearing in mind one persons doddle is anothers whole weekend ruined, just how easy are they to fit? I was quoted £114 fitted.
Iain
Iain
H reg 480 Turbo 135,000 miles - just run in really
Quid quid latine dictum sit altum viditur
- Big Brother
- Moderator
I’m the biggest scaredy cat in the world when it comes to doing jobs on the car myself but all it looked like was 1 bold on either end. I commonly assume that lots of parts are connected together so when you need to take off one part you have to take off loads of things but these seem pretty simple
Ad
Ad
2001 V70
- dragon
That is indeed about the size of it. Your biggest worry is loosening the nuts, whiuch will be full of crud - personally, I'd wire brish the crud off, wang some easing oil at it at least 20 mins before you start properly. This is especially sound advice if you don't have good quality tools which might start eating a rusted nut, or if you don't have a good long braker bar to help you out!
Gaz Wilson
Gaz Wilson
My shocks went like that on my old car. Just remember replace both rears at the same time.
Do get a decent socket that will fit it. It may be difficult to budge. If it's difficult to do leave it a few days, but put some of that easing oil on every day until you do it. Should make it a lot easier.
- Big Brother
- Moderator
tools required
They would probally stillpass an MOT as its only if they leak that they are a failure.
Tools required are one 17mm spanner and one 17mm socket and two Jacks one to jack the car up, and when refitting one to jack up the arm so the shock gets into place to do up the top bolt, you can install top or bottom last but i always do top last.
cheers Felyx .
p.s Bilsteins are £39.98 a pair from europarts i don't know if thats cos they give me trade price or not???
cheers Felyx .
One of mine is like that but it is still ok. If you want to save some pennies, and assuming they are still alright, just cut the rusted bits off and slip some motorcross fork boots on. Actually a good tip when fitting new ones to prevent crud ingress. I think ill slip some on my new Monroe's, when they turn up.
As long as the bolts are free the job is a doddle.
John
John
Citroen 2CV, lowered on 12" Wooden wheels, performance 1cm exhaust, stabilisers & chemical toilet in drivers seat
94 480 Turbo - now the missus's car!
Judas's car!! - 292BHP Celica GT4....I couldn't help myself!!
- dragon
Re: tools required
Unless they fail it for dangerous bodywork? Not sure where that particular area of MOT stops - whether it's just parts of the car that could come into contact with the public during normal use, or whether it takes the enire car into consideration (maybe to protect people who might work on your car)felyx wrote:They would probally stillpass an MOT as its only if they leak that they are a failure.
Dunno, you'd need to check the regs - I posted a link some time ago, but I CBA finding it
Gaz Wilson
Gaz Wilson
