Fron yellow koni's adjustment
iimomar
Post by iimomar » Thu Aug 18, 2011 10:37 am
Hi everybody,
I've recently installed yellow koni's on my 480. Now I want to adjust them a bit harder, the rear ones are easy to adjust, but to adjust the front ones I have to disassembly them. And here's the problem, to loosen the top nut I've to use a 22mm wrench and a 6mm allen to avoid the rotation of the stem. I did this but the only thing I had achieved is to bend the allen. I've also tried to loosen the nut before compressing the spring but with the same results...
I hope if someone has any trick o better way to do this job.
Cheers!
