I've found som wheels from a Renault, that i would like to fit on my 480 Turbo. The bolts and ET fits corectly, only an adapter for the centrumhole i needed. The only question i have left is if it will fit. Standard wheels are 14" 175/65, the wheels i want are 17" 215/45 (mm/% of height). So the are 40 mm wider, 20 mm on each side i guess.
Are they going to fit? Or are they to big!
Can you fit 17" 215/45 (mm/% of height) wheels on a 480
- dragon
- Volvo 480 Club Europe CREW
I think they may be too big - I have 205/40/17s on mine and although it's OK, there is some scrubbage on the inside of the tyres at full lock - I can only imagine this scrubbage to be worse with an extra 10mm on top of that...
Also need to make sure the offset is correct too...
Gaz Wilson
Gaz Wilson
- dragon
Didn't make much diff in my case - had some scrubbage before...
Gaz Wilson
Gaz Wilson
