Rear Bearings
Posted: Mon Nov 03, 2008 5:50 pm
by Loki
How easy is it 2 change the rear wheel bearings?
Mine are squeeking like a tw@ and only getting louder
All help + hints needed
Cheers peeps
Posted: Thu Nov 20, 2008 4:32 pm
by Kroost
It depends on the year your 480 is built in...
There are 2 types, the bearings that are fixed in the brakedisk and
the loose ones...
They are both pretty easy to change, for the first set you just
change the brakedisks at the rear, and for the other ones you
neet to press them out of the hub, and press the new ones in...
Posted: Tue Mar 31, 2009 6:36 pm
by LANTIN
Anybody got a reference for theses rear bearings ?
I have a 88 turbo with no ABS and can't find one.
Worse is that the partsbook doesn't even mention theses bearings but if I can manage to get a reference number, I'll be able to get one, even straight from SKF factory ...
So far, I've been told to change the whole hub
Can't belive I can't get a f@#&+ng bearing anymore ...
Posted: Wed Apr 01, 2009 1:39 pm
by LANTIN
OK got some new bearings.
Volvo P/N : 3411886
SKF : BA2B633313C
FAG : 545312A
I got mine from volvo, they are made by FAG.
Theses bearings are also listed as front wheel bearings for some old FIAT and Lancia cars.
