The Celeb is still pulling to the left despite me having the tracking done at 3 different garages over the last 6 months, I haven’t cerbed it at all. JT mentioned in another thread to get the tracking do after having brushes changed, can worn brushes be contribute to this?
Just a thought
Ad
Pulling to the Left
- Big Brother
- Moderator
Pulling to the Left
2001 V70
- dragon
- Volvo 480 Club Europe CREW
Bushes, worn steering rack, wheel balancing, even just incorrect tyre pressure can all contribute to pulling, as could some defect in the track rods (although I'd hope someone would spot that when doing the tracking), damage to wishbone, worn shocks, worn springs - all these can contribute to pulling...
Gaz Wilson
Gaz Wilson
- Big Brother
- Moderator
They will pull to the left as the Panhard Road at the rear makes it do so.It would pull to the right if it was mounted in the opposite way.This is regardless of everything up front being correctly set.Hundreds of pounds later I discovered this from Chris/Rich.
I'm No Longer Here :(
- Big Brother
- Moderator
