Grinding Stearing
piper1st
Grinding Stearing
Post by piper1st » Mon Jun 13, 2005 2:32 pm
I'm hoping someone can offer a suggestion for my first problem,
I am now a prowd owner of my first 480 ES 1.7i and it's make some low pitched noises when parking (like a squeeky shock). this problem doesn't seem to happen when going over 20mph. I've checked the power steering liquid and it seems fine. The car still steers fine, i'm just worried i'm damaging something?!
any suggestions or solutions welcome ....
Ross
p.s. if anyone had some luck with getting hold of new dials (speedo etc) please let me know.
Honda Civic ES I-VTEC
previous:
BMW E46 330i SE Touring
VW Mk4 Golf V6 4Motion
Post by pol » Mon Jun 13, 2005 2:43 pm
The power steering can be generally whiney. Is it not just noisy power steering?
piper1st
Post by piper1st » Tue Jun 14, 2005 10:43 am
actually ... you might be right. probably is just noisy.
as long as i'm not hurting my vehicle, i'm happy.
thanks.
Ross
previous:
vins480t
Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
Post by vins480t » Tue Jun 14, 2005 12:25 pm
powersteering is a pomp with a constant flow.
When a steering movement is maked the oil flows in that direction, which could give a sound.
If the steering is turned to the end the presure would bocome that high the internal emergencie overflow will open so the excesive flow can escape what will give an even louder sound.
There is no problem if that sound is heard.
Bramdeman
Post by Bramdeman » Wed Jun 15, 2005 9:54 pm
topping up the fliud (atf) usually makes the sound go away on a 480
'92 Red ES automatic
'88 340 1,7 Project car
stu chacks
Steering in the right direction...
Post by stu chacks » Thu Jun 16, 2005 1:55 pm
Try in the 'Steering' forum Ross, that's where I found the cure to mine...
http://volvo480.northernscum.org.uk/for ... php?t=5975
Stu.
felyx
Post by felyx » Thu Jun 23, 2005 9:42 am
it would be a good idea to totally flush (bleed) all the old power sterring fluid away this is meant to be done just the brake fluid is meant to be replaced (totally0 every 2 years i think, though quite often the fluid is 10 years old and just top up for brakes and especially steering.
cheers FELYX (pressure bleed kits by GUNSON cost about £12 and are easy to use)
