The last couple of days ,, I was sure something under the bonnet was becoming more noisy.
on my way hme from work this evening ( about a 15 mile jouney ) had the stereo cranked up and enjoyed a few quick corners, on the A and B roadsn which make my trip to and from work worthwhile.
I't msut have been getting worse , arrived in nottingham centre to pick up the missus . And a loud rattling / dragging , noise, acomanied by a warm synthetic smell beomes obvious. Thought my exhaust was dragging on the road.!
Jumpped out and looks under the car to see oil pouriong from the auxillary belt area of the car.
Shit ! , Was bricking , thought it was engine oil.. but then it stopped after a litre or so , ( and was red in apperance )_ then it clicked.
Soooo pleased my engine hadn't given up .. its only done 86K.
Managed to drive it back with no power steering ,, made a proper racket and the steering was ( as you would expect , really heavy) .
But , Now i am trying to fathom. What will a new pump cost , how difficult will it be to change if it is the pump ?
Any tips people , will be aplpreciated.
Power steering failure. i think!?
- Murf
if the fluid has leaked out everywhere from the aux drive belt area it sounds more like the reservoir that has cracked.
this is happening on mine as it weeps a bit of fluid and i have to top it up!
take the reservoir off the car, plug the holes for the hoses and fill it up and see if/where it leaks from. this will at least help you rule it out if its not the problem. if not it could be the hoses or the rack itself?
its all about trial and error and looking to see where the fluid is coming from
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
Well ,,
i did put som,e more fluid in , just as a test and it leaked straight out from th pump vacinity. Positive it's not the reservoir. Teh pump is knakerd . Sounds liek a really lump bearing has collapsed in the pump. Will remove tomorrow.
have been to the pub since and made some phone calls and managed to line up a second hand replacement from a source made last summer in ripley. £ 30
Will begin the dismantling process tomorrow.
Wish me luck
Wish me luck
Sorted it
managed to get a pump for £25 at a very friendly volvo / saab breakers in ilkeston. well chudffed!
About a 3 and ahalf hour job . .removal , and refit .
The bearing in the pump had given up and disintegrated .. found a few mangled ball bearig whilst replacing the unit.
Just replaced the unit , refitted the alternator , belt , tentioned it up ,, filled with steering fluiid and , no problems .. touch wood
Little bit tricky getting spanners in and removing nuts / bolts but...
All is good in the world of 480.
changing the fluid
How do you change the fluid of the power steering ??
Do you also need to bleed it ???
How are you sure you will get oll the old fluid out of the system i.e. how do you empty it fully ???
greetz and thanks
greetz and thanks
