Knocking from rear suspension
Everytime the car travels over a bumps in the road , you hear a knocking from the rear suspension. Where should I look first?shocks perhaps?.
Mileage is at 75000
Mileage is at 75000
- Big Brother
- Moderator
knocking from rear suspension
Thanks..I have had the exhaust checked recently, and it seems to have been mounted properly. My gut feeling is that the sound comes from the actual suspension at the rear of the car.
Thanks for your reply.I will check this out. The rattling knocking sound that I hear suggests that this could be the culprit. How do you check if worn? see if there is any movement when grasped or levered perhaps. Any suggestions welcome.
Pete
Pete
Re: knocking from rear suspension
you might be able to lever them to check for movement, though I'd just replace tehm anyway, they are only 22.00 From volvopeterjameo wrote:Thanks for your reply.I will check this out. The rattling knocking sound that I hear suggests that this could be the culprit. How do you check if worn? see if there is any movement when grasped or levered perhaps. Any suggestions welcome.
Pete
1996 Mini Classic 1275.
Sounds good advice. I will order the parts from Volvo at the earliest.
Many thanks for your suggestion.
- levensnevel
Might be possible that you 'bumbstops' are knackered.
One they replaced the 'old' ones at the rear of mine the 'knocking' stopped.
Niets of niemand zegt dat het echt moet
En toch, of juist daarom,wil je het beleven....
Gammal kärlek rostar aldrig!
Sweet memories
at this moment a Toyota Prius editione Tech MY2008 - 203K km+4K km
knocking from rear
Re bumpstops..Could be I,ll check thisout as well, thanks.. The noise is generated from only slight "bumps" in the road tho.
- rpruen
That sounds very much like the rear anti-roll bar links.peterjameo wrote:Re bumpstops..Could be I,ll check thisout as well, thanks.. The noise is generated from only slight "bumps" in the road tho.
To check... Have someone rock the car from side to side, and watch the bearing part of the link, if it moves then it's in need of replacement.
Be carefull when removing them if the bolts are tight. The brakets they bolt to are only spot welded to the car. Too much force and they will fall off.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
knocking from rear
Anti-roll bar links replacement. I wonder how much Volvo would charge me for doing this?
knocking from rear
Thanks you've encouraged me!! I'll pick a warm day first tho...I've gone a bit soft in my old age....
shocks
Of all the 6 volvo 480's i've had i have never found one that did'nt need new rear shocks, the ones i just took of my two tone had not rusted but had done 130,000 miles !!!!!!!!
and if they don't get replaced they start hammering the bushes and links.
cheers felyx
cheers felyx
