Front shocks warning!
Posted: Thu Dec 30, 2004 7:28 am
by dabac
I've just replaced my front shocks, and while the shocks themselves didn't look too bad the top mounting plates were just about gone!
The rubber pad that the top of the shock is bolted to had worked itself loose both from the mounting plate and brom the center bushing. I honestly don't know what kept the shock from torpedoing straight through the bonnet.
So even if your shocks arent that bad and you weren't planning on replacing them, have a look at your mounts.
Posted: Fri Dec 31, 2004 9:46 am
by lee
this is quite a commom problem with people who drive mainly in town/cities. This is to due to the vast amount of pot holes and speed bumps we have to content with every day.
When ever you change your shocks you should always change the top amounts as well. They cost around 35 pounds from the dealer.
Posted: Sun Feb 13, 2005 8:36 pm
by chris1roll
Does anyone know id that is that £35 each, or both?
Mine are looking a bit ropey,
If i push down on the car, you can see the centre of the strut, with the plastic cap on it, move up and down..the rubber stays where it is.... does this mean its shot?
Can hear knocking coming from the front at low speeds over bumps.
just looked on eurocarparts and they want £45 for one side and £37 for the other
Think it'll have to carry on knocking for a while!! Else i shall see if i have any decent ones lying about.....
Posted: Sun Feb 13, 2005 8:40 pm
by chris1roll
Oh, just looked on VADIS, I see its the whole top of the shock, the metal plate and all...kind of explains the price.....
hmmm, new clutch or suspension and put up with standard boost......
Posted: Sun Feb 13, 2005 9:01 pm
by Tiny_UK
mine are knocking when i go over pot holes sometimes. Aint sure if it is the sussy or the anti roll bar. Am thinking the anti roll bar as when i go over a pretty bumpy patch the steering wheel moves from left to right slightly.
Are these pads all round? cos if they are i will get all four done and the roll bars.
Posted: Sun Feb 13, 2005 11:21 pm
by Ben Harris
that's each, and it's closer to £50 from Volvo, if I remember correctly!
Ben.
Posted: Mon Feb 14, 2005 9:52 pm
by chris1roll
Oh....
/whimper.
part no
Posted: Thu Jul 28, 2005 8:33 pm
by V480TI
Somebody knows the part no for a 1991 volvo 480 turbo.
After reading the story's I went to Volvo and ordered a pair.
But now I am not sure if I have ordered the correct ones.
In a week I get new yellow Koni's and I want to be sure everything is oke .
Also the rubber things that are fitted in the triangular metal piece (wishbone????) where parts click in, can they be worn out or broken ??
If I look at it, it seems little parts of those rubber bushes are gone.
Greetz and thanks
Posted: Thu Jul 28, 2005 9:10 pm
by chris1roll
Thay do wear out, but are quite reasonable from volvo (£40 all four) aren't that hard to change providing the bolts aren't seized in, and make a big difference to the handling.
When changing my starter, my top mounts are looking much worse now- one looks torn
Cars turning into a bit of an expense at the moment, what with a warranty claim on a brand new tyre going on, and me having to pay up front for a replacement......
replacements
Posted: Thu Jul 28, 2005 10:09 pm
by V480TI
When I looked on the screen of the computer at my Volvo dealer I saw that I ordered some round rubber things, to be placed under where normally nuts (some cars other) are screwed on in the engine hood to hold the complete shock assembly.
Hope it is clear enough, but have I ordered the right thing ????
Greetz and thanks
part numbers
Posted: Wed Sep 14, 2005 6:39 pm
by devries
sorry
Luck, Mark
Re: part numbers
Posted: Fri Sep 16, 2005 12:20 pm
by Jamo
devries wrote:if you want to know partnumbers,you can download ***** via edonkey ,it is easy to find,it will take awhile to download,the files are about 1500 mb.
Luck, Mark
I'd be very carefull about posting stuff like that on public forums as you leave yourself and forum open to liable action for copyright infringements.
On other forums i frequent the said car programs are given nicknames to get around this.
Quite a few car fourms have had letters from the manufacturers on this.
Just a friendly warning.
Posted: Fri Sep 16, 2005 5:28 pm
by chris1roll
Still haven't replaced mine.....MOT test on Wednesday
