Squeaky Steering
- Big Brother
- Moderator
Squeaky Steering
When I turn a slight corner usually left I can hear a constant squeaking coming from somewhere under the bonnet. I don’t have a clue what it is and as it only does it when the car is moving.
Can anyone help me?
Adam
Can anyone help me?
Adam
2001 V70
- robkendall
a mouse stuck to the flywheel?????
lol
rob
lol
rob
- Big Brother
- Moderator
- robkendall
it could possibly be the brakes?
i have a problem with mine that they squeak all the time.
i think its just vibrations on the discs, from the pads.
some cars you can get shims etc.
my s40 only does it going around corners...so thinking it could be that?
rgrds
rob
rgrds
rob
- Big Brother
- Moderator
- sallysal
I had new back brake pads and a caliper fitted last week, brakes are fab, as is the hand-brake now, but I now have a squeaky wheel ( I think a front one; garage checked the front brakes, said they were fine)...... the squeaking started a few days ago just after I got the car back from the garage.
I've checked for wayward rodents, but none were to be found ........
If I accelerate hard the squeaking disappears, if I'm rolling along I hear it, and when I apply the brakes it stops.
Is this a "good gawd woman, get yourself to a garage without delay" situation or is it nothing to worry about?
S
S
1995 M reg 2.0l flamer, with Ltd Ed interior, sadly departed, but not forgotten
- 480 Rookie
Oh!!
I just paid £280 for my MOT and had 4xnew discs and 4xnew pads and 4x bushes.
It squeeked a bit before - now it squeeks loads more!! I'm gonna get my man to look at it after payday - he said it shouldn't be the brakes.
I've had the handbrake cables adjusted up loads and one side is sticky. He says both the cables need replacing but he just bodged it for the MOT (he knows i am skint)
The squeeking gets worse after using the handbrake - maybee the handbrake is pulling the discs a bit even when its set to off?
Will update when he's had a good look.
no fluid--- bet that was funmartinholmesuk wrote:
I had this a few days then we worked out there was no fluid
If brakes are squeaking and errent rodents are not to blame then you must ask yourself why you do not keep a family of small furry things within your nice warm engine bay - its a charitable act that I encourage all to perform!
Try copper-greasing the back of the pads - some garages don;t bother when they change pads coz they're lazy - but this may only fix you if your squeaking is as you apply brakes...
Try running the car in an <empty> car park and killing the engine then steer - as you no longer have power-steering you will be able to see whether its that causing the squeak <and how heavy the steering is without the hydraulic assistance!!>
Greta - 1994 2.0 480 GT
- Dan the 480 Man
Ok..
Thought i'd post here as opposed to opening a new thread. I also seem to be suffering a whine-type of noise when i turn left. The powersteering fluid is fine, and the brakes and stuff aren't new so thats wiped out those areas. Did anybody cure theirs?
