taurus dimensions
Rachel
taurus dimensions
Post by Rachel » Wed Nov 15, 2017 7:30 pm
Anyone know the Taurus width and offset please??
Re: taurus dimensions
Post by jamescarruthers » Wed Nov 15, 2017 7:41 pm
Taurus 6J X 15" ET 33
195/50R15
195/55R15
3462739-8
From the main site: http://www.volvo-480-europe.org/volvo480/wheels.php
Post by brinkie » Wed Nov 15, 2017 7:44 pm
I would choose the 195/55-15 tyres though, the 195/50-15 may be cheaper but it looks skinny and the speedo will be off.
Rachel
Post by Rachel » Wed Nov 15, 2017 8:00 pm
Thank you both very much, tyre and wheel dimensions are an just an enigma to me,I'm getting there though! I'm trying to get all the measurements together to get my 17" wheels on my 480. They have previously been on a 480 but I'm not sure if they needed a spacer and I have the added issue of my repaired wheel arches on the rear which with the lowered springs do occasionally rub on big dips on the road, I think the extra width will be inwards though so shouldn't be an issue. I'm going to put all the measurements into "will they fit.com" and see what that says.
Rachel
Post by Rachel » Wed Nov 15, 2017 8:01 pm
These are what I roll on at present.....Thanks.
Rachel
Post by Rachel » Wed Nov 15, 2017 8:56 pm
anyone know the actual rim sizes??
Post by jifflemon » Wed Nov 15, 2017 10:53 pm
195/50R15
195/55R15
3462739-8
Right there (in bold).
6 = 6 inches
The "J" symbolises the shape of the tyre bead profile.(it honestly means the shape of the rim looks like a letter J, And is thankfully pretty damn standard now!)
ET is the crucial part of your looking at changing wheels.
This is the distance in mm between the centre line of the wheel rim, and the line through the fixing face. You can have inset, outset or neither. This determines how the suspension and self-centring steering behave. The most obvious problem that will occur if you get it wrong is that the steering will either become so heavy that you can't turn the car, or so light that you need to spend all your time keeping the bugger in a straight line. More mundane problems through ignoring this measurement can range from wheels that foul parts of the bodywork or suspension, to high-speed judder in the steering because the suspension setup can't handle that particular type of wheel.
Inset and outset are subsets of offset and the relationship is this : positive offset = inset. Negative offset = outset. Typically you can get away with 5mm-7mm difference from the vehicle manufacturer specification before you'll run into trouble with the wheels fouling the suspension or bodywork. So for example if your stock wheels have an offset of 33mm and you can only find replacements with a 35mm offset, that 2mm difference ought to OK.
If your asking because your moving up width’s, we’ve many, many more calculations to do!
Post by jifflemon » Wed Nov 15, 2017 10:54 pm
195/50R15
195/55R15
3462739-8
6 = 6 inches
Post by jifflemon » Wed Nov 15, 2017 10:56 pm
So good, I thought i’d (Drunkenly) post it twice! Sorry!
Rachel
Post by Rachel » Thu Nov 16, 2017 10:08 am
Thank you so much for your reply. I know they should be ok as they used to be on my other 480, but this one a bit lower and has had replacement wheel arches.
