knocking coming from o/s rear
darren975
Post by darren975 » Sat May 15, 2004 5:33 pm
hi all
have got a knocking coming from what sounds like rear o/s. its not a consistant knocking.
just had her MOT'd, and had new wheel bearings and a new ball joint fitted. just wondering if any of you old hands have got any idea's as to what it could be?
like i say it is more of a thud - not rythmatic just occurs on uneven/bumpy roads.
darren
480ES 2L 1994 Red
mogge
Post by mogge » Sat May 15, 2004 6:05 pm
Hi darren!
Sounds like one of the ball joints isn´t secured correctly( if it´s the rear you had replaced)
Did you change wheelbearings at the rear?
/Jonas
Engineer
darren975
Post by darren975 » Sat May 15, 2004 6:33 pm
had it done by the garage. when i first got the car back knocking was gone. just recently it has started knocking again.
just checked invoice and it said "o/s lower ball joint replaced" - is this on the back??
480ES 2L 1994 Red
Murf
Post by Murf » Sat May 15, 2004 9:16 pm
no, i think the only ball joints are at the front.
there are linkage arms in the rear though that can cause that sort of problem.
do you have a turbo? due to the turbo having a bigger exhaust it often bangs on the crossmember as it passes over the rear axle.
it does it on my car and i had to finely adjust it to get it to stop and replace the rubber donut things in the middle of the car as they support the exhaust too.
check this first, even if you dont have a turbo as your donuts might be missing! :D
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
mogge
Post by mogge » Sun May 16, 2004 7:37 am
Hi!
Sorry, got it wrong whith the ball joint. Thought it was the ball joint for the roll bar.
/Jonas
Engineer
volvofox
Post by volvofox » Sun May 16, 2004 10:56 pm
i have a turbo and i had a massive exhaust problem. adjsuted it time and time again, even made an additional vertical damper, made out of a other volvo damper, and inox steel
it indeed "listenes very tight" not much play.
but still no results !
the x-es time i looked at it i accidently held the horizontal drag link and heard the same noice! Moral of the story, check the rear axle rubber bushings... (not seen at mot !)
luck,
JPF
Nomen est Omen
darren975
Post by darren975 » Sun May 16, 2004 11:07 pm
cheers for all the ideas guys.
@volvofox, would the rear axle rubber bushings make the noise when the rear wheel goes over a bump? was wondering as after a few laps of local safeway car park going over the speed bumps wasnt making noise every bump went over?
anyway will keep u posted
480ES 2L 1994 Red
allthingsvolvo
Post by allthingsvolvo » Mon May 17, 2004 12:59 pm
CLICK ON THE LINK & LOOK AT THE 480 REAR SUSPENSION PAGE.
THE LINK ROD YOU HAVE HAD REPLACED WAS MODIFIED & IF YOU BUY THE GENUINE ONES IT STOPS THE ANNOYING KNOCK...
http://anythingvolvo.mysite.freeserve.com/
volvofox
Post by volvofox » Mon May 17, 2004 10:18 pm
@ poster :
no, the noise wasn't always audible at all bumps. But on a real bad road it was an ongoing sound..just check play. piece of cake, maybe its not it.
@ althings :
i just swapped the horizontal drag link to another of a similar old car, checked if they looked alike (only the plastic handbrake cable bracket was improved by a simple steel one )
and no more rumble. So maybe your theory is right, but no solution, as proofed. (don't shout please) :)
luck,
JPF
Nomen est Omen
dabac
Post by dabac » Fri Jan 14, 2005 4:28 pm
volvofox wrote: Moral of the story, check the rear axle rubber bushings...
Which ones? There are a few...
rpruen
Post by rpruen » Fri Jan 14, 2005 7:00 pm
The rear anti roll bar links tend to do that on bumps, they are easy to change. Mine do this also, I have the spare parts, but as yet haven't replaced them.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
chris1roll
Post by chris1roll » Fri Jan 14, 2005 7:36 pm
Oh yeah, forgot about them, they've been in your car for months haven't they?
Still, i suppose rather more fundamental things, like engines, tend to take priority don't they? ;)
rpruen
Post by rpruen » Fri Jan 14, 2005 8:14 pm
Yes the things have been in the car for ages. I have got used to the noise now so it's not bothering me any more. I think it's time they where done though.
I wouldn't like to think what would happen if it let go while going round a roundabout at half throttle :)
The new engine is doing ok, so it was the injector for sure, since I'm now making more power than before.
Richard
dabac
Post by dabac » Mon Jan 17, 2005 9:13 am
rpruen wrote: I wouldn't like to think what would happen if it let go while going round a roundabout at half throttle :)
If you're talking about the drop links to the rear sway bar/anti roll bar - dont worry. Some of the 440s don't even have one fitted. I have (unintentionally) only noticed that something was wrong with my drop links (front as well as rear) when they spontanously self disassembled on the road. At both those occasions I simply taped them up to stop them from rattling and drove home. If your shocks are in decent shape the drop links aren't critical.
chris1roll
Post by chris1roll » Mon Jan 17, 2005 6:44 pm
I remember now, the mounting on the car body for the rear drop links are only spot welded on in two places. When we got my car, one of them was hanging off, and I welded it back on. (because I did it its not the prettiest welding, but its stayed there 2 years)
They tend to shear off on the track too.
