Anyway - I've done some searching on the net, and I believe the "spider" is more commonly known as a "Tripod CV joint". I also think that's what's most likely to have happened, is one of the little rollers has probably come off, as described in section 7 below.
Has anyone taken this apart before, and could advise if this is likely to be the case? I know that to dismantle the inner CV joint on this side, you have to drain the gearbox oil. Is there anything more to it? - Should I attempt it myself, or get a garage to do it? The car's still driveable, it vibrates horribly whilst going along, but I could get it to a garage, if need be.
Help!
Ben.
Non-Volvo text, taken from general website:
INBOARD JOINT (TRIPOD TYPE)
1. Cut away the boot and clamps. In some cases, a boot-retaining ring is used instead of a clamp. Use a brass drift to drive it away from the outer housing.
2. If the joint is to be reused, be sure to mark the relative position of the rollers with respect to the tracks they go into. Reassembling the joint in the wrong track could result in looseness, binding, and/or premature joint failure.
3. Remove the outer housing from the tripod. In some instances, this might require slightly deforming the tripod retaining rings or tabs with pliers or a screwdriver.
4. Wipe the grease away from the end of the half shaft.
5. If a snap ring is visible at the end of the shaft, remove and discard it. Otherwise, move the spacer ring back on the shaft and slide the tripod assembly away from the end of the shaft so that the cir-clip is exposed. Remove the circlip and discard it.
6. On some cars, the roller bearings are not held on the tripod by snap rings. If the joint is to be reused, wrap tape around the tripod to prevent the rollers from falling off.
7. Remove the tripod from the shaft, using a hammer and drift to tap against the base of the tripod. Do not pound on the roller bearings.
8. Clean the splines of the shaft. Apply a light coat of grease before reassembly.
