front subframe swap
madmax2471
front subframe swap
Post by madmax2471 » Fri Jun 18, 2010 3:19 pm
Hi
can anyone tell me if a 1990 or 1994 volvo 480 front subframe will fit my 1988 480?
The cars they would come out of would be a 2ltr manual but mines the 1.7none turbo manual version.
The reason I ask is that there are 2 480's being broken near me and I need welding done on mine for the mot, also Im going to fit a new clutch and timing belt at the same time so engine will be out anyway.
Any help would be much appriciated.
Re: front subframe swap
Post by glasgowjim » Fri Jun 18, 2010 3:29 pm
sub frame should be ok its the rear engine mount thats different. If there is no great difference in terms of rust go for the 1990 as its nearer your year.
