Steering system (I don't know the name of part)
bigdickbuster
Post by bigdickbuster » Tue Apr 27, 2010 1:55 am
Hello!
One of the elements of my steering system have major loose. I decided to fix it. But how to make it? Anyone have experience with this? I have spare part.
It's element 25 on the picture
Thanks in advance :D
P.S. What is the name of this stuff?
Re: Steering system (I don't know the name of part)
Post by glasgowjim » Tue Apr 27, 2010 5:17 pm
It is just a nut and bolt tat each end . this part of the steering column can move up and down in the direction of the steering wheel so dont be alarmed by this . Can you be more precise in explaining exactly what you mean by loose?
bigdickbuster
Post by bigdickbuster » Tue Apr 27, 2010 11:18 pm
Steering wheel have loose left - right, about 2-3 cm :shock: It's very annoying, driveability literally sucks :tomato:
Post by glasgowjim » Wed Apr 28, 2010 5:41 pm
Ah I understand now Adrian :)
Easy to check kneel on ground lean into the driver footwell and look at the steering rod the bit between the 2 number 25 bolts.
Grab hold of the steering rod in one hand and hold it still with the other hand try and move the steering wheel . This will show you if there is play in the upper part of the steering .
Now repeat for the little length of column that enters thedrivers footwell is there any movement there .
If the whole length of the column is firm then it must be the steering rack that is worn OR possibly the fluid needs topped up .
Post by glasgowjim » Wed Apr 28, 2010 8:01 pm
Just a mad thought maybe your ball joints are totally knacked :lol:
bigdickbuster
Post by bigdickbuster » Wed Apr 28, 2010 9:29 pm
I raised the car on the jack. Steering column was replaced three months ago and haven't loose.
Everything except steering rod is OK :wink:
Thank you from the mountain = Thanks in advance - literally translation of meaning in Polish-English :rofl:
Post by glasgowjim » Wed Apr 28, 2010 10:21 pm
an even sillier thought when you secured the steering wheel to the column you should make sure that the coloumn is fully engaged into the wheel .
Pull column up and then bolt down tight so that the top of the column protrudes above the level of the nut.
bigdickbuster
Post by bigdickbuster » Wed Apr 28, 2010 11:07 pm
OK, I'll check this point :D
480s partner
Post by 480s partner » Tue May 11, 2010 2:39 pm
Adrian, take a look here:
http://volvo480.dragons.org.uk/forum/vi ... 15&t=17267
Maybe that will help you!
bigdickbuster
Post by bigdickbuster » Tue May 11, 2010 4:52 pm
muito Obrigado :wink:
480s partner
Post by 480s partner » Tue May 11, 2010 5:07 pm
You're welcome! :cheers:
