I wrote that handling is much better. But it isn't perfect, so dampers must be changed anyway. Just like the steering transmission. I noticed leak of steering fluid
ES swaying like turtle while drive
- bigdickbuster
- bigdickbuster
Yesterday I noticed major loose in left rear wishbone.
The result is, that wishbone can move front and rear during drive.
So this is probably reason of problems with steering while car driving fast, because ES is swaying independently of the quality of the road.
There isn't a rear wishbone, only the front suspension has wishbones. You mean the bushings from the panhard rod or the trailing rod? These aren't expensive and difficult to replace. Also check the rubbers from the swaybar with which the swaybar is connected to the chassis and also check the swaybar's droplinks while you're at it.Yesterday I noticed major loose in left rear wishbone.
- bigdickbuster
Re: ES swaying like turtle while drive
Swaying like a turle?
well I've never swayed a turle but think I get the idea, mine was the same at the back end changed shocks and anti roll bars......now rides great. noticed that bump stops are one missing one knackered? next job!
