Changing front suspension arms (wishbones)
Post by glasgowjim » Sat Nov 21, 2009 1:26 pm
Well car failed on the bushes - yes all of them on the front suspension arms so , changed the drivers side took a while but it was doine with any mahor problems , so today did the near side or tried to , off came the old one easy then the new one in place manouvered about and well the driveshaft has slipped out of position for one , cant get the last of the two chassis bolts in position. So thought take a break and think abpout it have lunch a then blitz the problem .
Now the rain is pelting down I stll am no further on so will try to postion the hub so the drive shaft locates and bolt up the lower wishbone arm then try the last bolt.
Oh have used spring compressors to relieve pressure on the hub.
Any thoughts guys as its driving me nuts . I am terrified that I snap the rubber gaiter and spill the oil all over the road :cry:
Post by glasgowjim » Sat Nov 21, 2009 4:44 pm
well went out undid the other bolts and worked the other way round finished the last 30 minutes of the job in the rain still its all done and tightened to the correct torques so only the brake pipe and hose to do then take it back to test centre. :lol:
stug723
Post by stug723 » Sat Nov 21, 2009 5:04 pm
good luck jim, sounds like you have your hands full.
I'm still trying to fit a 21st century bathroom into a 19th century house!!!
stug
Post by glasgowjim » Sat Nov 21, 2009 5:40 pm
Went out to try the car but was disturbed to answer a phone call so when I returned I forgot to remove the spring compressors before putting the wheel on DOH! :lol:
bigdickbuster
Post by bigdickbuster » Tue Dec 01, 2009 2:33 pm
Jim, you must change your drug dealer :wink:
Or maybe try to use some mixture for improving memory :D
Of course, legal :o
