Re: any ideas changing over driveshaft
Posted: Mon Oct 17, 2011 11:06 am
Mine is a rotational clicking that can be felt through the car when I turn left and is worse when the car is loaded up. There was loads of oil on the wheel when I removed it.glasgowjim wrote:At hard lock in one particular direction you hear a clear knocking sound the cv joint/bearing is gone.
Yes you will need the special use once bolts , cv boot oh and spring compressors.
I dont have any spares driveshafts left for sale.
It has to be that really eh? As the tripod spider at the other end should be fine.
So I can just buy the CV joint and attach it to the driveshaft?
