any ideas changing over driveshaft
spree
Re: any ideas changing over driveshaft
Post by spree » Mon Oct 17, 2011 11:06 am
glasgowjim wrote:At hard lock in one particular direction you hear a clear knocking sound the cv joint/bearing is gone.
Yes you will need the special use once bolts , cv boot oh and spring compressors.
I dont have any spares driveshafts left :cry: for sale.
Mine is a rotational clicking that can be felt through the car when I turn left and is worse when the car is loaded up. There was loads of oil on the wheel when I removed it.
It has to be that really eh? As the tripod spider at the other end should be fine.
So I can just buy the CV joint and attach it to the driveshaft?
Post by glasgowjim » Mon Oct 17, 2011 2:30 pm
http://www.eurocarparts.com/ecp/c/Volvo ... 1&5f858a1e
look up this and your question is answered :lol:
spree
Post by spree » Mon Oct 17, 2011 11:54 pm
glasgowjim wrote:http://www.eurocarparts.com/ecp/c/Volvo ... 1&5f858a1e
Ok yes sounds like it deffo is the outer cv joint.
Is this the cheapest place to get it from you recon?
Post by glasgowjim » Tue Oct 18, 2011 6:38 am
No just the handiest for checking on parts. GSF or other companies may do the same. Its just there is a Eurocarparts depot close to my work so I always check there.
