Steering fluid leak
Posted: Sat Jan 17, 2009 5:17 pm
Hi all
My PAS system dumped all its fluid suddenly, and when I refilled it, it held before switching engine on, but when running it sprayed fluid out from the pump area.
It was booked into a garage to have some other bits looked at so I asked them to confirm diagnosis on this, too.. they said it's definitely the pump.
I got a second hand pump today, fitted it, and it does exactly the same thing. Fluid sprays out around the pulley area and is flicked in every direction by the belt. So I either have two broken pumps, or two OK pumps and there's something else wrong.
Is this familiar to anyone?
I found this thread http://volvo480.dragons.org.uk/forum/vi ... hp?t=15057 I'm hoping the rack is fine, but the "power steering fluid leaks out at a significant rate" seemed familiar..
Thank you
Dave
Thank you
Dave
