Anti Roll bar
- Jimmy
Anti Roll bar
One of my MOT advisories was:
Nearside rear anti-roll bar has play in a ball joint
Any idea if this is easily repairable and whether a novice could tackle it?
Well the part numbers you've got referenced there are for front ones.
edit: theres these drop links http://www.partsforvolvosonline.com/pro ... ts_id=5258
1990 Volvo 480 Turbo - Sold
1994 Volvo 480 Turbo - Sold
1990 Volvo 480 ES - Broken
Re: Anti Roll bar - FRONT - DROP LINKS
Good evening Rocket and Jimmy. Very interested in your exchanges as I need to renew my FRONT nearside drop link. Its 'groaning.' For life lubricant finished? Cost from the suggested link incl. p.&p. is £15.83 for one. I have not got the 'good news' from Volvo parts yet! A couple of Q's. Are these spares reliable and really up to Volvo's spec? Assume I too should renew both? All that is needed is a 17mm spanner? I've been advise to ALSO get new nuts?
Golly Gosh
Re: Anti Roll bar
You'll need 2 17mm spanners, one open end spanner to lock the backside of the nut. Best is to replace both at the same time, but that's up to you. It''s an easy job, you just have to remove the wheel. Try here. to get them at a good price&quality. New locking nuts are included.
Re: Anti Roll bar
Hello again iroll480. Drop links have arrived. I note that whilst on the RHS one the 'fittings' - nut and bolt - are at right angles to the link/bar those on the LHS are angled outwards? One more than the other? Assume this is correct or is it? They seem a rigid fit not flexible? They do have the correct part numbers. Manufactures Scan Tech Sweden altho at least one was made in Taiwan.Iroll480 wrote:You'll need 2 17mm spanners, one open end spanner to lock the backside of the nut. Best is to replace both at the same time, but that's up to you. It''s an easy job, you just have to remove the wheel. Try here. to get them at a good price&quality. New locking nuts are included.
Golly Gosh
Re: Anti Roll bar
I can't remember if L&R differ. But it's easy to find out by comparing them with the ones on the car.
Re: Anti Roll bar
new they are quite stiff. i thought the same with new lower ball joints, when they are bolted on they will move easily.just a tight fit. they are not handed, same both sides.
