Hi guys and girls,
My car is making a creeking noise from the front left wheel area inder steering eg reverse parking and turning into sharp corners and also setting off from stationary. Also the car shakes or vibrates badly at high speed. Any ideas?
Owen
Creeking when steering and shaking at high speed!
- 480 Tatey
Volvo 480 Celebration 19/480 now sold. Gutted.
http://s251.photobucket.com/albums/gg283/Tateys480/
The creaking is probally anti roll bar links rods about £13 each on the front one each side of the car and easy enough to fit like 20 mins a side or less .
take the wheel off and if when you grab and rock the anti roll link bar it clicks then it needs replacing. some people call an anti roll link bar a DUMBELL because it looks slightly similar. p.s no independant garage should charge more than £30 to fit them and if they do go elsewhere...
cheers
cheers
- 480 Tatey
Got the wheels balenced and the vibration is not as bad, but the creeking is still occouring and when i took it in for the last service they reported that everything was fine with the steering and all components around the wheels eg rods, bearings etc. But the creeking has gotten slightly worse since then and when pulling off with the steering wheel stright it creeks then when it never did before? Ive been told it could be the steering rack? Any help or suggestions would be really helpful!
Owen
Owen
