Rear/Front suspension overhaul...some questions.
- Dan the 480 Man
Word.
I'm going to be repairing my rear arch next year (not long after Xmas hopefully), and while everythings off i'm going to be replacing as much as i can (afford ).
I've been doing some searching on the forum, and discovered some interesting things along the way. I've been on 'www.partsforvolvosonline.com' and sourced the things i need at a reasonable price.
Front droplinks (to do) are £12.10 inc. vat.
Rear droplinks (which i presume are universal fitment) £11.09
Not on the site, but available are rear shocks: KYB 'Excellence' Oil filled, which are a perfect fit (my Dad has them and no knocking) which are about £30 each. I'm happy to use these as oil filled was Volvo's choice, unless somebody can recommend good ones for the same price (bearing in mind i'm -40mm)?
Is there anything else that could be changed whist there? I did read about a shortened Panhard rod for lowered cars which came with the 480 lowering kit, and somebody did mention that it was available seperatley from Volvo. Does anybody know if it is, and if it's beneficial to have it or just to leave mine as it is?
Oh, and exhaust rubber bushes thingys that hold the backbox in place...mine are looking pretty worn...
Front:
Shocks obviously. I had my drivers side wishbone replaced this year so the bushes are quite good in those, but the passenger side bushes need doing. Front droplinks-now, sounds stupid, but i found an old pic of Marts front suspension, and there appeared to be 2 drop link bar thingys on one side-is this right? My top-mounts are ok though...
Those things i know i'll be doing def. Is there anything else that i should pay particular attention to? I did think ball joints, but i'm not sure how worn or how old they are. Apart from the obvious play in the wheel (not that mine has), is there anyway to see if they could do with replacing or should i just leave them?
I just want to do as much as i can in one hit-and the parts at the mo for the rear aren't too expensive.
Just wanted anybody's opinions or advice r.e. things i've missed out/can do. Cheers!
Front:
- Dan the 480 Man
- owen080808
looks an extensive list to me. things which might be worth checking but prob not vital could be anti-roll bar bushes. or track rod ends/the bits that it steers with, come on you know what i mean wheel bearings? now i really am clutching at straws!
probably a big huge can of wd40 to loosen all those lovely coroded on bolts would be helpfull too
Currently car-less
| '92 turbo + Rich mod | Sold
Dan mate!
The shorter (by 5mm!!) Panhard Rod was only available as part of the Volvo Lowering kit.This has long since been discontinuedus.
You rear suspension bushes are going to be in need of a change though,unless your service history tell you otherwise.
These comprise of the drop links you mentioned each side.There the Anti Roll Bar Bushes which are only £3 each from Vulva and are a piece of piss to slide over yer bar,ooer!
Then theres the ones which require taking off the car and running down to a garage with a 10 tonne press to have them changed over.
These are the Torque Arm ones front and rear,otherwise known as Trailing Arms,which go from the top of the rear hub to the rear bumper area.Then the Radius Arm ones each endus.Also Panhard Rod bushes each end.
I went to get mine in Downham Market from Hylton Gott and the whole rear axle bushes were £103 incl VAT with 10% off.
Basically mate,it stops the rear end swaying about.I didnt think mine was until I fitted new bushes.Its now as tight as a swans passage!
Oh,and its not worth getting the shorter Panhard Roddus unless youre going to lower the car 20mm,have 5mm shorter arb links front and rear and shorter shockers.As I say,these are no longer available anyway.
Good Luck chappy!
Steve
Good Luck chappy!
Steve
- Dan the 480 Man
Hmmm...
Maybe it's going to be as much as i realy can afford! Was thinking about the old Plastic friend, but i think i'm just gonna save save save as it sounds like it's going to get expensive!
A few more q's Groomy...
The bushes you mention that need doing with a press-are these the same as the arb bushes? May sound a twat for asking, but i've no idea what it all looks like down there! And how many of those arb bushes will i need? And i presume that these bushes that need the industrial press (if not the same) are quite expensivvvvveeee?
Has anybody got an exploded diagram from Dr Who that i might be able to see? The PC i use for that program is unavailable! If i know how much it's gonna cost, i can start selling whatever i can lay my hands on on eBay
Oh, and when you say it cost you £103 for the lot, what does 'the lot' comprise of?? Cheers dude!
Dannium!
The arb bushes of which there are just 2,are pieces of rubber you just slide over the anti roll bar and push along it until theyre at the place where their brackets hold them to the back axle.They dont need a press.
I can bring a price list when we meet up to swap ECUs if yo want.I can show you whats what as well also if thats any good.
Haaaapppppyyy Noooooyeeeaaar!
- Dan the 480 Man
Sure no problem I have all the bushes and the paperwork from Volvo sorted ready for you now in my garage ready to go matey.
Thats a fucking awesome avatar too man!
Could you send me a screen sized file of that??
