i have replace the washers on the powersteering pump/top pipe about 4 times, each with two new washers.
arrowed in the picture.
it keeps on leaking..
so, how tight can i do this bolt up without breaking the top pipe connector? according to form this top pipe is sold as one part#, and perhpas doing it up too tight might cause it to break and buy that turbo.
so how tight should it go? its prettey tight already you see
power steering pump washers keep leaking.
1995 480 S 2.0 237,000 Miles
I have done this a few times already, there were 2 washers on there each side of the top pipe, where it meets the bolt.
Some people have said that I don't need one on the bottom of the bolt/top pipe (PS pump side) so i'll give this a go when i've got a minuite spare at work...
Stephen
Stephen
