power steering pump washers keep leaking.
suddy
Post by suddy » Mon Nov 06, 2006 8:23 pm
i have replace the washers on the powersteering pump/top pipe about 4 times, each with two new washers.
arrowed in the picture.
it keeps on leaking..
so, how tight can i do this bolt up without breaking the top pipe connector? according to form this top pipe is sold as one part#, and perhpas doing it up too tight might cause it to break and buy that turbo.
so how tight should it go? its prettey tight already you see
1995 480 S 2.0 237,000 Miles
martinholmesuk
Post by martinholmesuk » Mon Nov 06, 2006 9:30 pm
It's a banjo bolt, undo and replace the copper washer.
Audi TT
suddy
Post by suddy » Tue Nov 07, 2006 7:20 pm
I have done this a few times already, there were 2 washers on there each side of the top pipe, where it meets the bolt.
Some people have said that I don't need one on the bottom of the bolt/top pipe (PS pump side) so i'll give this a go when i've got a minuite spare at work...
Stephen
stu chacks
Post by stu chacks » Tue Nov 07, 2006 10:31 pm
Tried with a torque wrench Suddy? Shouldn't need to on that, but wouldn't do any harm (and you wouldn't have to be afraid of overtightning then either)?
Stu.
JohnTurbo
Post by JohnTurbo » Tue Nov 07, 2006 11:03 pm
sholdn't there be just one washer top, and one washer bottom?
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
suddy
Post by suddy » Sun Nov 12, 2006 4:30 pm
There is one washer top and bottom.
I tightend it as tight as i could get it this afternoon, so we'll see if there are any morn problems.
Stephen
