Does anyone have a press for new bush fitting???
catgroom
Post by catgroom » Wed May 10, 2006 7:37 pm
I'm totally rebushing my rear axle atthe end of this month.
So,I need a press!
I'll be changing the anti roll bar links and bushes without the need for one.Its the trailing arm,radius arm and Panhard Rod bushes that will require the pressure method!
Help much appreciated and shown by waving cash about!My rear axle is floating around on corners like an old Cortina with the void bushes shot!
:D
I'm No Longer Here :(
stu chacks
Post by stu chacks » Wed May 10, 2006 7:51 pm
JT's tip of using a standard bench vice worked a treat when I did the front wishbone bushes Groomiester. As long as the jaws open wide enough should do the trick.
Stu.
catgroom
Post by catgroom » Wed May 10, 2006 8:52 pm
Thx Stu!
I'll give it a go if JT says it could be done!
Nice one!I love my DIY ;) :D
