Does anyone know if the seals/grommets that join the brake fliud resevoir to the brake supply pipes are availible anywhere else apart from Volvo.
I've been qouted £54+vat which for a 6 rubber seals seems expensive.
There are 2 feeds coming out of the bottom of the resevoir so two of each are needed.
Volvo P/N:
- seal : 3435454.
- small nipple : 3435453.
- big nipplie : 3121179.
Any links/tel numbers of suppliers would be a help.
Thanks,
Chris.
Brake resevoir seals
oldtimer
1987 480es
1987 480es
Hi Chris!
You could try going through this Scantech catalogue
http://www.scantechsweden.com/UserContr ... _Volvo.pdf
I beleive ATE make mine,but seeing as yours is an '87 vintage it would have Girling brakes I guess.They would surprisingly also make those parts too.
A Girling link which is pretty good is this one.
http://www.classicgarage.com/parts.html
Good Luck matey!
Steve.
Good Luck matey!
Steve.
I'm No Longer Here :(
