Rer Caliper Leaking
Rer Caliper Leaking
Post by pol » Thu Oct 06, 2005 8:10 pm
Hello hello.
Been playing around with little niggles on my car the last few days as haven't been working.
I went to adjust the handbrake, as you do and found fluid behind the adjuster dustcap on one of the rear calipers. So it would seem it is leaking. Not good.
Thought I had seen this mentioned here before but cant remember where. What would cause it to leak there? Is the adjuster connected to the back of the piston? Indicating knackered seal on the piston??? What else can go on these and does anyone know if you can buy a service kit or the likes...
Whadyasay?
cheers,
Post by pol » Thu Oct 06, 2005 8:18 pm
Just found the other post.... Still wondering about replacing seals yourself..
