Took my beloved 480 for its retest today, new seatbelt working superbly, handbrake adjusted etc. But again it failed due to 'no reserve travel on handbrake'. This caliper was replaced last year and he reckons it is applying pressure, but not enough and not soon enough.
I'm going to take it back to the place that replaced the caliper last year (I've only done 6k miles this year and there aren't even any hills in Hull) and see what they say, but what is reserve travel? The handbrake works fine!
A frustrated Rob and off the road 480.
MOT Failure: The Sequel
1989 Black ES
- Agwa Moose
Re: MOT Failure: The Sequel
From that I'd guess he means it's not reacting fast enough when you pull the lever, probably a slack cable, tighten it up and see if that sorts it out, might be an idea to check adjustment at the calipers as wellshaughnessy10 wrote:he reckons it is applying pressure, but not enough and not soon enough.
Could be an idea to ask whoever did the mot exactly what he means
J
- robkendall
take up the space in the caliper with the adjusters?
i think for the mot, your allowed 3 locks (ie...the wheels lock the rollers)
but for overall, theres some equation to work out overall performace....you have to hit a minimum of 50%.....
if youre loose on one side, it could drop the whole down below this?
not sure exactly what reverse travel is?
rgrds
rob
rgrds
rob
