Break disks, maybe time for replacements?
Big Brother
Moderator
Post by Big Brother » Mon Feb 28, 2005 4:58 pm
While I was checking out the breaks today because I can hear them grinding and squeaking occasionally I found the disks were quite badly rusted around the edges and I don’t know if the lines I can see on them are cracks or just bad stains as it won’t wipe away. Going to have them looked at properly tomorrow.
2001 V70
dragon
Volvo 480 Club Europe CREW
Post by dragon » Mon Feb 28, 2005 5:11 pm
I'd say they are OK at the moment - yes the edges are rusted, possibly very rusted, but they aren't the braking surface, so it's OK. Run your finger from the braking surface up to the edge of the disk, how much of a "lip" can you feel? If it's a couple of mm, they'll probably be fine for another few hundred miles, but if there's a serious lip to them, then yes it's probably replacement time. And what better time to start playing with mechanics yourself, as replacing discs and pads is fairly straightforward - was the first "proper" job I did on my turbo myself :)
As for the diagonal lines - I don't think it's to worry about, the discs that came off the turbo had them, and the discs that went on as new also had something similar. Watch someone tell me I'm wrong and find out I've been driving a deathtrap before it went to DBSs home for upgrades!!! :lol:
Gaz Wilson
Big Brother
Moderator
Post by Big Brother » Mon Feb 28, 2005 5:15 pm
I did run my finger along it but I couldn’t feel anything, I could only feel a slight lip when I ran my finger nail across it so I guess that means they are ok, I was planning to change the disks and pads at some point and anyway and yes I am going to do them myself :) I have the Haynes book of lies to guide me and my dad can make sure I’m doing it right.
Ad
2001 V70
chris1roll
Post by chris1roll » Mon Feb 28, 2005 5:57 pm
Those lines are where someone, at some point has caned the brakes from high speed to a complete stop, rather than easing off towards the end of braking. The pads then partly fuse to the disc, leaving those marks. This contributes to pedal judder. I found this from the net somehwere, i'll try and find the link later.
Had: 1989 ES with added boost, and terminal windscreen cancer :(
[img]http://img.photobucket.com/albums/v477/chris1roll/forsignature.jpg[/img][img]http://img.photobucket.com/albums/v477/chris1roll/Polished.jpg[/img]
The voices in my head might not be real, but they have some pretty good ideas..
dragon
Post by dragon » Mon Feb 28, 2005 5:58 pm
Since you said that, it makes sense, and after looking at the pics again, there are 2 oppsite lines, making the rough outline of the pad! :D
Also, caning of brakes generates lots more heat in the disc, which could well explain the advanced flakiness on the rim compared to the apparent lack of wear on the braking surface.
Certainly wasn't me doing that heavy braking, btw: I reserve that for turbo cars when racing certain automatics!!! :rofl:
Gaz Wilson
martinholmesuk
Post by martinholmesuk » Mon Feb 28, 2005 6:22 pm
:rofl:
:lol:
Not the same day the brakes started to smoke :rofl:
:oops:
Volvo 940 Turbo 19T
Audi TT
Big Brother
Moderator
Post by Big Brother » Mon Feb 28, 2005 7:13 pm
I see what you mean Chris. I will be replacing them sometime in the future but the shocks need doing now and these have a couple of hundred miles left in them.
Ad
2001 V70
dragon
Post by dragon » Mon Feb 28, 2005 8:20 pm
Something's been bugging me since I posted on this topic last - chris indicated the marks are caused by someone stamping on the brakes all the way to a stand before letting the pads off the discs.
But the car has ABS, I would have thought the action of the ABS would allow for enough cooling as it rapidly releases/applies the pads under extreme braking?
Gaz Wilson
pol
Post by pol » Mon Feb 28, 2005 9:29 pm
Still going to get hot under harsh braking.. Yep, those marks do look like the outline of a pad, but cant say i've ever seen it before...
pol
rpruen
Post by rpruen » Mon Feb 28, 2005 10:20 pm
It's because they are also the handbrake.
The rear pads also operate when you put the handbrake on, so if the brakes are hot when it is applied, then it will leave material from the pads on the disk. There isn't much you can do about that, other than to drive gently for 10 miles after harsh braking, before putting the handbrake on.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
vins480t
Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
Post by vins480t » Mon Feb 28, 2005 10:58 pm
or just leave it in gear and no handbreak at all
or put it stopped at the pavement
V!nc!en[color=red][b]T[/b][/color]e
