Grinding brake?? General moan...
alfonzobonzo
Post by alfonzobonzo » Thu Jan 13, 2005 8:04 am
theres a noticable-bad sounding grinding noise comming from the front left wheel (i think) when i reverse or brake heavily after driving for long periods without braking,
at first i thought it was rust building up on the surface of the disk (what with the wet weather an all) but it shouldnt happen that quickly?? & it doent explain the revering thing...
the car was standing for just over a week at christmas, and when i used it for the first time i notice that the hand brake had welded itself to the disks somehow.
Oh, and my mid section exhaust a
has developed a crack, right where it joins the rear section, ha ho, its a 480 so now ive got a headache.....Joy
:wave:
Alfonz.
Toyota Celica G7 Tsport Storm Blue (LiftTastic)
480 L 1994 2.0 i Metalic Black K&N Panel SOLD (fond memories)
V40 W 2000 1.9 T4 SOLD (kind of miss it)
Murf
Post by Murf » Thu Jan 13, 2005 10:13 am
could be the pads are worn down to the metal. check the level of brake fluid and if its quite low then check your pads!
all i can think of other than that is a wheel bearing on its way out!?
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
alfonzobonzo
Post by alfonzobonzo » Fri Jan 14, 2005 11:47 am
:shock:
yep, shone a torch in there last night to look at the pads, near side very thin offside non existent!!
theres obviously no brake warning light operation for pads then?
:shock:
Alfonz.
Murf
Post by Murf » Fri Jan 14, 2005 2:44 pm
yes, there is. theres a warning buzzer for when your pads get low, it sounds like a kinda grinding noise :rofl: :rofl: :rofl:
1992 480 Turbo
alfonzobonzo
Post by alfonzobonzo » Fri Jan 14, 2005 6:22 pm
hmmm, yes .
crude but effective. :D
Alfonz.
MatBat
Post by MatBat » Fri Jan 14, 2005 6:34 pm
If they have ground down to the metal and you've had metal to metal, then you'll need pads, and discs.
1996 Mini Classic 1275.
chris1roll
Post by chris1roll » Fri Jan 14, 2005 7:31 pm
Even if there was, you should never rely totally on it, there isn't an electronic substitute for good maintenance, especially where brakes are concerned.
And i'm not preaching here, when i had my 440, age 18, i drove it untill the brakes made grinding sounds, I now check them regularly, (as in every other week or so) and would never ever let them get down to less than 2-3mm now, and shudder at the thought of what could have happened back then!
matbat wrote:If they have ground down to the metal and you've had metal to metal, then you'll need pads, and discs.
What he said :D
JohnTurbo
Post by JohnTurbo » Fri Jan 14, 2005 9:18 pm
Ahh there was the time my oz aloys on the ibiza chewed through the flexible hose. I clamped it off with mole grips, and drove home 40miles. That was scary braking! Think it was jealous, since my dad was driving my 480 in front...i'd just gone to pick her up!!
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
alfonzobonzo
Post by alfonzobonzo » Mon Jan 17, 2005 9:20 pm
fixed that then, discs were ok,
replaced cat & mid section at the same time
everything was well in 480 land............. UNTILL....... :cryhard:
Alfonz.
