Front discs/pads
Front discs/pads
Hi there,
Time to change the front pad/discs.
How about
V64147 BRAKE PAD SET-RE TEX O.E 480 Turbo 86>93 TEXTAR 18.50
Or
V64149 BRAKE PAD SET-RE PAGID 480 Turbo 86>93 PAGID 15.25
Or
we can supply a set of EBC kevlar pads @ #27.50 + carriage at #8.50. Regards
With
(front discs) Mine is a turbo 93 with ABS. Are the below correct?
V62219 BRAKE DISC-FR 256mm 480 Turbo 86>93 Vented Discs 16.00
Or
V60119 BRAKE DISC-FRONT 256mm 480 86-95 Vented Discs 21.00 (don't say Turbo)
What discs and pads are you using?
Cheers!
How about
Or
Or
With
Or
Cheers!
- dragon
- Volvo 480 Club Europe CREW
I was using standard replacement discs/pads from GSF, cheap as they came for the turbo, did the job pretty well, but then it wasn't exactly flying as a car when they got changed
However, be prepared for this job - you may or may not need all or some of the following (in addition to a standard tool setup )
Penetrating easing oil (not wd40)
Long (at least 2m) sturdy pipe for leverage
Impact Driver
Good quality sockets
Caliper key (or suitable allen)
Copper Slip
New knuckles
Patience (lots of it, especially when trying to push back the rams in the calipers
Good luck
Impact Driver
Copper Slip
New knuckles
Good luck
Gaz Wilson
Gaz Wilson
- dragon
Prolly wont help for the disc retaining screw (which is the one thing that caused me to go buy an impact driver) - mine was mangled, but even if it wasn't, I don't think a regular driver would have done it!
Gaz Wilson
Gaz Wilson
- JohnTurbo
Best way to get the disk retaining screw out is with a small metal chisel. Gets them turning pretty fast, the hub/shocker bolts are evil MO-FOs. if you can get them off, sure as hell replace them with new ones!!
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
- Jamo
Ho ho ho, this not fun, remember myself, Lee an Tony up till 3 am doing mine. Dont forget blow torch and tapping tools.dragon wrote:I was using standard replacement discs/pads from GSF, cheap as they came for the turbo, did the job pretty well, but then it wasn't exactly flying as a car when they got changed
Impact Driver
Copper Slip
New knuckles
Good luck
Had to heat up alot of the bolts to get them to move and tap set to remove sheared bolts.
- Jamo
Impact driver all the way on these, have to be carefull do to strip the head though.dragon wrote:Prolly wont help for the disc retaining screw (which is the one thing that caused me to go buy an impact driver) - mine was mangled, but even if it wasn't, I don't think a regular driver would have done it!
Ouch this job brings back baaaaaaaaaad memories
- robkendall
arent the two bolts that hold the caliper onto the suspension leg chamfered?
i found that they were round on mine, and had to cut them off, the redrill/tap new holes etc...fucker of a job
better now though
green stuff do nice discs and pads that fit, but a bit expensive...grooved and crossed drilled etc....mutts nuts
rgrds
rob
better now though
rgrds
rob
- JohnTurbo
It was the memory of the front discs that triggered me to buy a £150 teng hex (not shitty bi-hex) socket set.
A set of imperial bihex and a lump hammer have got me out of some tight nut situations in the past though.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
Oh, i love changing 480 front discs. No actually, i don't do I?
Martin, make sure you use decent tools, its the caliper bracket bolts (chamfered ) that will cause you grief!
I'm using the Red dot grooved discs (£105 (solid)) with the proper volvo pads (£30ish)
Chris
Chris
- Bramdeman
Before your start on each wheel have some fun with the brakes, their comming off anyway, everything comes out a hell of a lot easier when its hot! Have to work fast though or it cools down again.
Oh and be carefull not to burn your fingers
'92 Red ES automatic
'88 340 1,7 Project car
no, I will see if my dad will give me a hand, He is changing the astra brake tomorrow and he knows how to do all this stuff.MatBat wrote:martinholmesuk wrote:Another easy 480 job. I might have access to some air tools.
I hope this doesn't mean, I am doing it!
BTw it's a piss easy job, (with air tools) 3 mins each side for front pads and discs. I got mine for £30 for both discs and all pads.
Last edited by martinholmesuk on Wed Aug 03, 2005 11:40 am, edited 1 time in total.
- Jamo
Yeh only if the bolts aren't rusted or stuck in, every caliper bolt on mine required a blow torch heat up and breaker bar to get them to move.MatBat wrote:martinholmesuk wrote:Another easy 480 job. I might have access to some air tools.
I didn't have a torch available so I ended up cutting the heads of mine off by drilling into the center of them until the heads broke off. Then when I got the caliper loose I put a nut on the protruding end of the bolt and MIG-welded that in place. After that heating it didn't take too much force to back out the remains of the old bolts.chris1roll wrote:.. make sure you use decent tools, its the caliper bracket bolts (chamfered ) that will cause you grief!
