brake noise
gsa60
brake noise
Post by gsa60 » Sun Oct 05, 2014 6:33 pm
Greetings,
My rear left brake makes a noise like a shopping cart when driving on bumpy roads. It's more like a can of beans rumbling through the street :lol: .
When the brakes are applied the sound stops . Either with foot brake or handbrake.
Can this be due to the anti-rattle spring thing on the caliper? It does not look bent. I looks like the spring on the other wheel.
One ore question: there is only one spring for each disc, correct?
Cheers.
Re: brake noise
Post by glasgowjim » Sun Oct 05, 2014 7:50 pm
check your rear wheel is on tight .
the answer to your question is yes 1 spring only
gsa60
Re: brake noise
Post by gsa60 » Mon Oct 06, 2014 12:02 pm
Yep. That's tight :D
gsa60
Re: brake noise
Post by gsa60 » Thu Oct 16, 2014 10:13 pm
Any more sugestions?
Re: brake noise
Post by glasgowjim » Fri Oct 17, 2014 8:24 am
It could be the rear shock absorber is a little loose .
