Relais of the ABS en TC pump
Arie480
Post by Arie480 » Tue Mar 12, 2013 12:11 pm
Hello
I cannot seam to find the relais of the ABS en TC pump. The are not in de relais box on top of the strut near the windscreen. My 480 is a GT model 2.0 liter of 1996.
I have sean somethin simelar at the bottom of the pump, but I don't now if the relais is located there and how top open the housing and change it. There is an electrical malefuntion in the ABS pump. The sensors and conections are all in a good shape.
Kind regard's
Re: Relais of the ABS en TC pump
Post by glasgowjim » Tue Mar 12, 2013 4:05 pm
The ABS relay is clipped to the bottom of the abs pump.
It is a long black relay 8cmx2cmx4cm
Arie480
Post by Arie480 » Wed Mar 13, 2013 2:31 pm
Do I have to move it in an upwards motion ore downwards ? I am unable to move it.
Post by glasgowjim » Wed Mar 13, 2013 9:09 pm
The relay is clipped VERY TIGHTLY onto the underside of the ABS pump. here are some photos of the relay itself....
you should be able to worrk it out for youself from the slightly fuzzy photos.
