Rear Brake Caliper / Discs
keithrturner
Post by keithrturner » Mon Mar 22, 2004 6:05 pm
Just failed my MOT !! Rear n/s not braking on handbrake. Was informed that could be seized caliper. Can I give this an overhaul myself, if so how? or is it easier to fit a new one?
Also suggested that I need new discs are these easy to fit?
Any help appreciated!!
This forum is great, helped me sort loads of problems ..... speedo. window mechanism, door, rear lights, glad I'm not the only one with these problems!
allthingsvolvo
Post by allthingsvolvo » Mon Mar 22, 2004 6:18 pm
;) Rear calipers are £64.00 each with a years garantee P&P is about £10.00 insured royal mail delivery rear discs few different types with hub no hub ? Fr £17.00 each.
interested pm me. :)
CHESH740R
Post by CHESH740R » Mon Mar 22, 2004 6:54 pm
Try adjusting the handbrake adjusters that are within the caliper first before buying a new one.
Rear discs, as long as it isnt the ones with hubs, then its a doddle of a job.
The Haynes Manual gives pretty good step by step instructions if your a novice at doing brakes.
