REPLACEMENT BRAKE PADS
Golly Gosh
Post by Golly Gosh » Mon Aug 02, 2010 2:14 pm
Has anyone purchased any front and rear brake pads recently ~ if so where from please?
Have tried suggested sources in past posts but either 'not in stock' or no response.
For info Volvo are quoting £36.80 + vat for front set and £32.80 + vat for rear set.
I have a 92 480 auto turbo. Take it all models use same pads apart from those with ventilated discs?
Would much appreciate any advice or guidance. Thank you.
Golly Gosh
Iroll480
Re: REPLACEMENT BRAKE PADS
Post by Iroll480 » Mon Aug 02, 2010 2:27 pm
Try partsforvolvosonline.. They stock brake pads in different price ranges. Good service and quick delivery. The pads differ in vented and non vented discs and ABS and non ABS from memory. You can find a great guidance to replace the rear pads and discs in the howto section.
Golly Gosh
Post by Golly Gosh » Mon Aug 02, 2010 3:42 pm
Many thanks will do both. :D
Golly Gosh
felyx
Post by felyx » Tue Aug 10, 2010 7:41 am
or buy some EBC GREEN STUFF ones , which are about £35 and you may notice a 10% ish improvment in braking .
