ABS MKII flash code 3-4
Captain Crunch
Post by Captain Crunch » Sun Apr 11, 2010 9:31 pm
Hi!
I've been neglecting this forum for more than a year now, but I still hope someone in here would help me with my ABS problem :)
My 480 turbo -92 has a MKII ABS controller in the boot.
The flash code reads 3-4 indicating "Signal missing" from LH rear wheel sensor.
Could I measure the connections 24,6 in the MKII ECU to try to narrow down the problem?
Could it be a faulty cable, all the connectors in the ECU unit are clean and look OK.
480's never die, they just transcend.
Jens Lumbye
Storfors, Sweden
Captain Crunch
Re: ABS MKII flash code 3-4
Post by Captain Crunch » Fri Apr 06, 2012 1:51 pm
Fixed it! It was a faulty flywheel sensor. After replacing it works fine.
Jens Lumbye
Storfors, Sweden
