Had a similar problem - piston was 'sticky'. I worked the piston backwards and forwards and made sure the caliper moved ok on its pins.
Ah - just noticed the date so its probably to late - heh ho
hand brake doesnt release on one side
with seized hand brakes cables , sometimes this causes the hand brake to be on 20% lets say whilst driving which causes lots of heat (for agruements sake 300 degres C )
and not only does this screw the brake fluid on that caliper but can also seriously heat damage the caliper beyound repair .
cheers felyx
cheers felyx
